Stop in for a cup of coffee
Q5TjlSrnuSEjduBZm8LBwuctxXHFK0SMAtOcrpIr0Jj1B7OLmg7iv8pH0QkJK7gd2lPOOJEB&_nc_ht=scontent.fsan1-1.jpg
6011 is what we call farmer rod, burns thru rust and paint, white flux! 6010 for pipe red flux. 7018 for better strength needed applications gray flux but is picky about wanting clean metal. And if you are not handy it is difficult to run vertical. Bring back the memories?
I was using 6013 3/32 to weld 1/8 wall square tubing.
Yep, sure does.....thanks...
High travel speed required! 3/32 is the way to go on 1/8 material. You might grab a spare rod and beat the flux off of it and then use it as additional fill rod. Just dab it in when puddle gets to big. It both cools the puddle instantly and helps with not blowing out the 1/8 tube. Especially in the corners where the material heats up so quickly.
Sorry dunno, I've only seen the Vietnamese ones. Small cup with holes in the bottom, a flat press plate , and a lid. Bout 2" in diameter...
I have a video of one in Viet Nam in my phone , but cant post it, needs to be YouTube...
I grabbed an updated photo yesterday from after i replaced the line
Maybe more the filter further from the exhaust heat? IDK it might be OK there because it is in the air stream when the car is moving or fan is turning. I know thats close to factory but factory didn't have those headers. maybe a heat sheild under it?
Or loosen and rotate the fitting on the carb upward to get more clearance to the manifolds...
Found this video under my old account name. Was looking for french press vid. Anyhow this vid was shot in 2019 in the World Famous Ha Long Bay, in North Viet Nam....
