Stop in for a cup of coffee
Happy Birthday, turning wrenches in peace is the best way to spend a Birthday in my opinio
Thanks much...agreed
A little light reading to go with coffee this morning :thumbsup:
Thanks @halifaxhops for the tip on getting this booklet
Everything connected to the battery positive is hot
ok, I was checking around last night trying to find out where I had messed up with my wiring job as I was getting no voltage to the fuse block. part of what I did was hook up a volt gauge in my separate gauge pod. and when testing it there was no continuity across it. but there was continuity through the ammeter. and there is 12.6 volts on the battery side of the gauge and nothing on what would be the alternator side
Lesson learned. Ammeter is way different. Glad you caught it it can drive you nuts.
Hard to picture what how this has been rewired.
The ammeter is part of the circuit, except for '76 which uses a shunt wire.
Both studs should be at system voltage. No measureable resistance should be present in the gage. It acts like another section of wire unless the studs get loose.
I took out the ammeter and extended the ammeter wires which are now going to an external voltgauge. so now the voltgauge is not flowing current but stopping it to read it. so my fuse block is not receiving power
You can't use a voltmeter like that. In fact the only meter that can be put in-line is an ammeter
Master Technicians Conf. 67, p.22 Test Ammeters and Voltmeters
- unless its an externally shunted ammeter. Then the shunt goes in line and the meter is in parallel.
Like this
[/URL]
Like this
yes, I didn't realize that when I wired it which Is why I was going to Just feed power to the fuse block by tapping into the + side on the voltgauge
Morning fellers. snow is here, not so much the snow but the 40-50mph winds making it rough out. But does make the coffee and oatmeal taste better.
May you have no double feeds today and hope you don’t swap a single miserable small battery out the whole day. And of course keep your feet and your powder dry!
