Thanks Matt. I have 18° at the crank with timing light at idle. Then 36° all in with timing light about 2400 ish IIRC. The bottom chart shows all in by 1750 ish. So i am in slower than that. That is super fast!Engine willbe fine with vacuum advance when using a mechanical advance shaped like this.
or these
And with no vacuum advance it will be OK with a fast curve like this.
Can't mix the two.
Below 3000 rpm or so will result in too much lead time at light and part throttle.
It will manifest as flat spots on the throttle response and /or pinging under moderate throttle once the engine is fully heat soaked.
