Mattax
Just the facts, ma'am
For the most common version. Ouch!
Was called innerseal. Have a body shop buddy? Otherwise urethane.Hey the window on the Dakota poped out of the lower channel that raises the window. What do you use to stick it back in some sort of tape?
At least it is real. Just posted one for 135 actually.For the most common version. Ouch!
Urethane. Its bonded in. Regulator bolts to channel mounted to glass.Thanks I will ask Matt if he has some.
Will have to pull glass and channel to do it right.Urethane. Its bonded in. Regulator bolts to channel mounted to glass.
Blue heat sink s good to 6500. Picked up a mopar kit cheap from 97. I mean cheap postage was more than the kit. At least I know they were real now in 97.I should still ahve the one that came in the kit with the MP distributor. Might be a little more recent. I dont recall the blue heat sink. even if its the same p/n
Now I gotta try to remember when I bought the kit. I think I used the tach drive distributor first couple years. Then parts store distributor, then tach drive again with a MSD timing retard hooked to a vacuum advance can with a switch. Might have been around '96 or 97 when I bought the kit.Blue heat sink s good to 6500. Picked up a mopar kit cheap from 97. I mean cheap postage was more than the kit. At least I know they were real now in 97.
Chrysler Electric Ignition Conversion Pack 361 383 400 Point type to electronic | eBay
Wish I could say that. Time to get my a** in gear!Good morning all, no idea what’s on the agenda today. Drinking some coffee.
your motor home yet?Good morning all, no idea what’s on the agenda today. Drinking some coffee.
No, I will take trans and car back to NC to install everything. Ordered the last couple of things that were just delivered. Carb fittings for cross ram, water pump, starter, rad and fan shroud.your motor home yet?
Awesome.. i'm down to radiator,starter all that little ****... And valve coversNo, I will take trans and car back to NC to install everything. Ordered the last couple of things that were just delivered. Carb fittings for cross ram, water pump, starter, rad and fan shroud.
Yeah, i don't wanna end up with a pair that won't clear my rockers.. prolly gonna buy a set of the cheap welded up ones off amazon.. hate how they look but i know they will clear...I polished the original chrome covers and 1 came out great, the other not so much, needs to be redone. I got a set of ‘66 black ones.
440 Mopar Performance Valve CoversYeah, i don't wanna end up with a pair that won't clear my rockers.. prolly gonna buy a set of the cheap welded up ones off amazon.. hate how they look but i know they will clear...
Sadly i'm running a weak little 318.. which i know is a garbage motor but it will have to do
And I got the original barn dust $500 a bucket...$2500 for a trunk mat??
