Think mine is 48.75 Man I have shaft envy! Make sure you use a driveshaft loop! If the front joint fails it will be a stunt from the blues brothers movie!
But aren't you actually requesting someone to make/give you the shaft???? Not jealous hereTime to order a driveshaft! 57.75 inches... You A-body guys... don't be jealous of my massive driveshaft![]()
Actually... i just remembered they had me measure from the output shaft to the rear yoke... so i just lied about the size of my driveshaft.. it's gonna be bout 3" shorter than i saidThink mine is 48.75 Man I have shaft envy! Make sure you use a driveshaft loop!
As long as it's straight and has good balance.. i don't mindBut aren't you actually requesting someone to make/give you the shaft???? Not jealous here
I did also. Slept at an Air bnb that had an amazing mattress. I asked the homeowner what mattress it was. They sent me the amazon link. it was priced right also.Did the "Bed in a box" off Amazon...I appreciate the sleep
I switched to a foam mattress around 10 years ago.. still love it.. and soo much cheaper than old style ones..I did also. Slept at an Air bnb that had an amazing mattress. I asked the homeowner what mattress it was. They sent me the amazon link. it was priced right also.
That’s okay. Mine is a tad over 96 inches…Actually... i just remembered they had me measure from the output shaft to the rear yoke... so i just lied about the size of my driveshaft.. it's gonna be bout 3" shorter than i said![]()
I would be compelled to grease it vs oil it, it will stay in place betterSo here’s a question for you. Assembled engine minus cam shaft and timing chain. Currently oiled up and wrapped in plastic trash bags, is there a better way to try to keep it safe from moisture over the winter?
You're doing that actual harness wrap and not electrical tape right?k.. driveshaft order form sent off... i think that was the last big piece to get.. now it's down to meGot a little done last night.. i need to get on the wiring soon.. probably re-wrap the whole harness, they look soo much better with fresh tape. Need to find a switched 12v for the choke anyway...
Unfortunately no. The seller is in Michigan. I think they are so cool. I’ve never seen one in personThose specialty. 70s editions are so cool.
Is that local to you? Seems I've seen that car, or one very much like it.
I was considering STP EOS, I’ve used it before but that was to preserve a block not a freshly machine block. I think I’ll do that again. I just don’t want to risk the 440 at this stageI would be compelled to grease it vs oil it, it will stay in place better
I’m of the same mind set as you bud.I was on the phone for a few hours last night with an old Army buddy... we're close in age and he's made a career change getting into cybersecurity. We have an ongoing discussion around AI use. He loves it... I don't, and keep declining when Windows asks if I want to activate AI-assisted browsing and search. I have a strong distrust... Maybe I've watched Terminator and Matrix movies too many times.
Electrical tape.. harness wrap looks weird to me on a mopar.. the factory harness was just tape anywayYou're doing that actual harness wrap and not electrical tape right?
for doing it exactly like mopar did it?
