Have a good trip Wolfie! Stay safe
Morning dreamers!!
Looks like a nice day for outside housework here today. I have some older unreplaceable windows on the house. I'm going to caulk them shut and hopefully delay them in rotting away and having to be replaced.
Chiefs play the Donkeys tonight. My best buddy and wife are coming over to watch the game and discuss our trip to Hawaii together in Januraury.
Whats wrong with the transmission?Good morning crew. I’m off today. I take the dart over to get the transmission fixed and then off to bring the ford back to the house and drop the chevelle off at my in-laws. It’s being reduced to being stored in a car port![]()
Sorry to hear that but not a lot you can do about it.Good morning crew. I’m off today. I take the dart over to get the transmission fixed and then off to bring the ford back to the house and drop the chevelle off at my in-laws. It’s being reduced to being stored in a car port![]()
It’s slipping and the fluid smells burnt. It’s worse when it’s cold. I don’t have the room to do it myself at home. I took it over to my regular mechanic that specializes in transmissions so he’s going to take a look at it.Whats wrong with the transmission?
Hopefully it gets sorted out and doesn’t cost too muchIt’s slipping and the fluid smells burnt. It’s worse when it’s cold. I don’t have the room to do it myself at home. I took it over to my regular mechanic that specializes in transmissions so he’s going to take a look at it.
Probably a transmission service and band and linkage adjustment will tune that baby right up.It’s slipping and the fluid smells burnt. It’s worse when it’s cold. I don’t have the room to do it myself at home. I took it over to my regular mechanic that specializes in transmissions so he’s going to take a look at it.
He said if it needs a total rebuild $1800. He’s going to look it all over first. I didn’t think that was terribleHopefully it gets sorted out and doesn’t cost too much
Never had any!Break off?
Yup. Fluid level, linkage adjustment and filter would probably be the order I'd look at. Change the fluid and filter anyway if its burnt.Probably a transmission service and band and linkage adjustment will tune that baby right up.
Too bad you aren't closer. Lon could fix you up.He said if it needs a total rebuild $1800. He’s going to look it all over first. I didn’t think that was terrible
I have bought a few Mopars for cheap with the "transmission out" and did a service and drove away.Yup. Fluid level, linkage adjustment and filter would probably be the order I'd look at. Change the fluid and filter anyway if its burnt.
So do I.I shudder to think what I have sunk in transmissions.... hope it's a one-and-done repair
There's a chart in some of hte servivce manuals (most I think) showing which internal bands and clutches are engaged in each selector position. But first thing is correct pressures (fluid level and throttle linkage)
I wish I had the room to do it myself and learn all of that. It annoyed me that I can’t.There's a chart in some of hte servivce manuals (most I think) showing which internal bands and clutches are engaged in each selector position. But first thing is correct pressures (fluid level and throttle linkage)
