Stop in for a cup of coffee
:rofl: :rofl:
Weird. What is that diagram page from then? Is that page number in the reprint?
It’s from a digital scan of a 78 power wagon Factory Chassis manual. That page number is in my reprint, but it’s a different section all together.
Might be a mid year. Wolfie let me borrow a 64 TSM that had the V8 and Barracuda updates in it that mine did not have
Seen that with the '67 parts books. The first releases do not have the Barracuda. Those were added in as supplements, but later printings just included them.
Then there's AMC in the 1980s. Some year to year changes just aren't documented - at least in any obvious way. Might be service bulletins that are buried in a dumpster.
Might be. The truck was delayed because of the 400 block problem where they ran out of engines and only had the 360s left. It is a late September build truck
Thought I was done with the leaves. Friggin storm last night blew a bunch up from neighbors into the dogs area. Usually it all blows away from there. Will give it a couple days... If still there, I'll have to buzz them with the mower one last time.
Making mulch with lawnmower sounds better than running a rake by hand!
Yep. I rake very little any more. Just to pull them out from under the bushes. The John Deere does the rest. I blow them all into a windrow and drive over them to grind them up. Then put on the bagger to pick them up. I usually get 2 pick up loads when they are the worst.
Used to get a bunch out on our road but taking down 50-60 Alder trees seemed to help with that! Slowly replacing them with Evergreens. They would blow across the road to the neighbors yard but the biggest thing I didn't like was several could hit the powerlines.
I haven't even bagged for last few years. Just get them mulched before they get too thick, and they all disappear!
