I have a set for you. They need cleaned
Well I think the Steeler's are beat
Not to be nosy but why on earth do you want to take out headers for manifold? The advantage of headers span from fuel economy, more power, engine breathing, ease of working in engine bay etc etcOk I have a question. I want to eventually swap out the headers for a manifold. I have a 318 in my dart. I found these on marketplace place. 1973-1976 Mopar “A” Bodies | Mopar exhaust maniford great shape went with headers instead | Facebook
It says small block but is there anything else I should be looking for in regards to fit?
Nope, too new. The 68-70 340 manifolds are the first choice and the 71-74 manifolds are next best. There are combinations of LA and Magnum manifolds that work well too. There are many threads here on FABO about all those choices. Yes, if the headers are in good shape I would probably leave them.Ok I have a question. I want to eventually swap out the headers for a manifold. I have a 318 in my dart. I found these on marketplace place. 1973-1976 Mopar “A” Bodies | Mopar exhaust maniford great shape went with headers instead | Facebook
Working around the headers has been a bear for me. The run through all of the steering linkages. I couldn’t get them out of the way when I needed to get to the steering box before. The headers that are on there now are cheap ones and they aren’t in the greatest shape.Not to be nosy but why on earth do you want to take out headers for manifold? The advantage of headers span from fuel economy, more power, engine breathing, ease of working in engine bay etc etc
just curious, your circus your monkees!
I have been going through and trying to read as much as I can. Sometimes it’s gets a bit overwhelming with the headers vs manifold debate. Sometimes I just may not be searching in the right threads either I am sure.Nope, too new. The 68-70 340 manifolds are the first choice and the 71-74 manifolds are next best. There are combinations of LA and Magnum manifolds that work well too. There are many threads here on FABO about all those choices. Yes, if the headers are in good shape I would probably leave them.
Colts titans game was epic. It had EVERYTHING,6-0 game. You didn't want to watch that mess
Maybe research a good header that is correct for your application? Think, Dougs, TTI? Sounds like you may have an incorrect set somebody has made to fit somewhere along the way. A good fitting set creates a lot more room for most everything?Working around the headers has been a bear for me. The run through all of the steering linkages. I couldn’t get them out of the way when I needed to get to the steering box before. The headers that are on there now are cheap ones and they aren’t in the greatest shape.
Wait until you start looking at 318 cams.I have been going through and trying to read as much as I can. Sometimes it’s gets a bit overwhelming with the headers vs manifold debate. Sometimes I just may not be searching in the right threads either I am sure.
I'll look through my bookmarks and see if I can find a thread or two. I know I saved some about manifolds.@Petty Betty please note my point of reference is always hot rod or racer based. I do not restore! Very first thing I have done with every single Mopar is toss the exhaust and throw that miserable firewall electrical connections box in the trash! Then put in a roll bar so my opinion is biased as a result!
I was lazy and picked up a pizza
Looks more like a heavy weight fight.Too cold for yardwork today so we went out this afternoon and walked nine holes of golf.
Watching the Eagles- 49ners gearing up for the Chiefs game.
www.forabodiesonly.com
THat was last night. Nothing wrong with that. I got a large so there's some leftovers.I was lazy and picked up a pizza
Sounds like a command issue for letting it happen. Glad you're almost done.Sooo things I saw today at drill while officers and higher NCOs were giving briefings.
Two soldiers watching Netflix on their laptops.
One reading a romance novel.
Another sleeping under a pink unicorn blanket on the floor
Several females with pig tails and dreadlocks, one with bright f-ing neon blue hair paint.
And two soldiers…. Knitting scarves.
What the hell happened to the Army…
I understand that and I really appreciate the input. And as you guys know because it’s quite obvious my knowledge is low. I know basics so any knowledge you share is read and taken into consideration. I have been working my way through the forums and trying to read what I can and then Googling for more research.@Petty Betty please note my point of reference is always hot rod or racer based. I do not restore! Very first thing I have done with every single Mopar is toss the exhaust and throw that miserable firewall electrical connections box in the trash! Then put in a roll bar so my opinion is biased as a result!
It is. But not at the company level. It’s a battalion command issue. And in correction is attempted, the soldiers that were doing this crap, just scream race or gender or hazing or some combo of the above and the battalion staff backs down everytime. I’m glad though that my platoon is autonomous and we don’t have to interact with the rest of the company but this one drill a yearSounds like a command issue for letting it happen. Glad you're almost done.
