Stop in for a cup of coffee
Didnt check in, my internal clock is still wonky.
Neighbour/Doctor is dropping by for a scan, see whats wrong with his silverado. Hope its something simple.
So.. i'm gonna have to weld new perches on my axles (shoulda went with 275s) anyway.. i was gonna go with these, they are a bit longer than the moroso ones and i saw people bitching bout the moroso quality.. any reason to not just get the generics?
Just make sure the center pin size is the same. The Moroso ones use to fit the best way back when.
Anyone looking for a ton more room for your harness connections.................. I posted this in my build thread.
65 Dart under hood wiring? WTF is this mess??????Pictures of engine bay wiring desired - '65 Dart
Was gonna ask on the b-body forum but you guys would know.. is there nothing that holds the engine harness to the bulkhead? mine just seems to push on and that's it... I'm using my original '62 harness as it isn't cracking or dried out at all (wire insulation)
Clips on each side of the connector I believe.
Push in, there’s metal wire clips that hold them in on those years, in 64/65 they started going to plastic clips built in to the harness but they were inconsistent with that
