Stop in for a cup of coffee
There add says 62 - 82. I would still check.
I do know you have to cut the shaft some .
Yeah, my only real issue is i'm using a newer LA water pump but the older iron pump cars pump won't bolt up.. didn't know this before hand and now i can't just change the pump cause i already got a radiator that goes to the wrong side... i rule!
Here is a hot rod with a following!
I had that problem when I bought a new rad for my car. Water pump was a newer style. Had to get a 64 pump.
Yeah.. if i had known bout the PS pump issue i would have ordered the proper side on the radiator.. but i'm not replacing a $500 radiator now.. will figure it out.. Been watching FBMP and people want 150-200 for a used LA pump with brackets and i can't bring myself to pay that for garbage someone will end up trashing
Let me check but I have a new aluminum radiator with the inlets and outlets wrong. I bought it at Carlisle in a box that said Mopar for $125 and when I got it home it is not close for the 318 I have
I've got mine all installed and all.. plus the ECP is pretty :) I'll work it out... just need to get off my lazy ***... hearing the motor fire the other night got me really wanting to get it done now..
It's 3/27!
Good morning :D
Hmm....
This is on my 71 318....
Just looked it up.. they switched to the newer style in 1970... the one on yours is 62ish(poly had it) to 69
I am thinking of getting a borgeson power steering pump/gearbox kit.. did you go manual/power or other way or? I know it's not just a bolt in unit but how much bullshit was it?
I have factory manual steering, just getting rid of the sloppy coupler for a u-joint
you know.. manual steering might be the way to go... then i can fit a torqstorm on later :)
From red states bussing them in....fyi
Regardless of state colors, remember it is easy to speak from a distance about there not being a problem when you, personally, don't have to deal with the problem. Like me saying there is no issues with California taxes, gas prices, crazy rules and laws, because I don't have to deal with them myself living here. Now that they are showing up to the areas saying there wasn't a problem, it is suddenly a problem.
The real issue at hand, is "they" are creating a problem that they will "save" us from. While they rescue us, rights will be lost and too many people will be ok with that. Watch closely.
