Those were the days. (not my photo. I wish it was)
Single flare on copper only. Double on steel line.tighten/loosen a couple times to seat it. Anti-sieze between nut and tube will help you in the futureNo, where the line comes out of the fuel pump.. it's the only flare i did and the only leakI did a single flare, doing a double and fixing that once it's not cold out again.. then i will add water and pray those head gaskets don't leak.. been reading bad **** bout them.. not a big job but a pain to setup the sideplay in the rockers in the car compared to on a stand... if i have to
yeah.. soon as it warms up i'm gonna practice doing double then make a new line again.. in the last few years cold weather just stops me dead..Single flare on copper only. Double on steel line.tighten/loosen a couple times to seat it. Anti-sieze between nut and tube will help you in the future
Me too, i avoid playing outside when its cold. Shop is around 70f, i like it warm.yeah.. soon as it warms up i'm gonna practice doing double then make a new line again.. in the last few years cold weather just stops me dead..
Its on 95 s-10 chassis, 2.2 4cyl, ps/pb/ac and cruise. It will weigh about the same as the s10. Im fine with low performance.That's a stude? what's it gonna have for drivetrain? 360?
that's awesome, will be reliable.. cheap parts plus AC..Its on 95 s-10 chassis, 2.2 4cyl, ps/pb/ac and cruise. It will weigh about the same as the s10. Im fine with low performance.
Same. I can sit up until midnight pontificating,and hit it in the morning with a poorly executed plan..yeah... my garage is decently warm but i dunno... when it's cold out i just go home and wanna hibernate.. soon as i go in the house i rarely come back out.
Yup. It was a low mileage truck as well,80,000 mile on itthat's awesome, will be reliable.. cheap parts plus AC..
I need to get my hands on a can of that. I could use it at work.
We do think alike, as I look down at my no heel flat shoe with wide toe box!Essentially, the height difference between the heel and the ball of the foot is zero.
It rotates your pelvis to a more neutral position and aligns your knees and ankles.
Usually accompanied by a wider toe box so things like turf-toe and bunions are less impacted.
Smart guy to practice on a chunk of line.yeah.. soon as it warms up i'm gonna practice doing double then make a new line again.. in the last few years cold weather just stops me dead..
I bought a hydraulic flaring tool. Makes three types. Made all lines on my 5th wheel. Converted from electric brakes to hydraulic disk. Works great. And it was not real expensiveSmart guy to practice on a chunk of line.
yup.. trying to avoid buying a $100+ tool for 1 flare.. which between the cheap tool and wasted tubing would put me over 200... will figure it outI bought a hydraulic flaring tool. Makes three types. Made all lines on my 5th wheel. Converted from electric brakes to hydraulic disk. Works great. And it was not real expensive
I can loan you my tool.yup.. trying to avoid buying a $100+ tool for 1 flare.. which between the cheap tool and wasted tubing would put me over 200... will figure it out![]()
Naw.. if i can't get it with the current tool i will buy a good one.. i'm just cheapI can loan you my tool.
You see thisDestroying Experimental Turbine Cars #TurbineCar
