Stop in for a cup of coffee
The initial "Oh cool" as I was driving by the lot...
Then disappointment
Then a lot of disappointment
Brake lines all ran. Fuel filter replaced. Oh, my bad-its not a diesel so its a gas filter. Replaced it anyway.
And fixed up the exhaust. So some more scaling and paint frame tomorrow. Then is done.
I was accused of lack of knowledge in regards to a “fuel filter” thats when i took the oppurtunity to mansplain the issue.
I paid more than that in the wrong location. :(
But I wanted the tank full before heading home. So it goes.
No idea why its going up now. The refineries don't have to start sendin summer fuel until May 1.
I don't know but winter fuel is when they use additive around here and not summer.
OK... had to look it up
A primary difference between winter- and summer-blend gas is their Reid Vapor Pressure (RVP). RVP is a measure of how easily the fuel evaporates at increased temperatures.
The higher the fuel’s RVP, the more easily it evaporates.
Winter-blend fuel requires increased RVP. If the fuel doesn’t evaporate readily in cold temperatures, the engine will start hard and run rough when it’s cold outside.
To achieve this, refiners often blend winter gasoline with butane, a relatively inexpensive additive with a high RVP. They adjust the RVP of the final formulation to as high as 15.0 psi to help the gasoline ignite readily in the cold.
Once the temperature warms up in summer, however, high-RVP gasoline can volatilize more easily, which contributes to increased emissions and air pollution.
For that reason, federal law restricts sales of gasoline with an RVP greater than 9.0 from June 1 through Sept. 15.
To comply, refiners reduce the amount of butane in the gasoline and instead use pricier additives, hence one reason gas prices generally increase in summer. The blending process also takes longer, adding to the cost.
Except Cali.... which has a 7.0 RVP requirement
they're allowed get to cut it with more benzene tolulene and cheaper stuff to improve low temperature starting. \
Unfortunately we get some hot days here before switchover. Then I can smell the fuel and the car doesn't like it much either
A lot of places have additional restrictions on RVP.
At least one state has a drivability requirement. Its one of the midwest states IIRC but I forget the details.
I think they are just trying to get ahead of the curve.
