Stop in for a cup of coffee
Still up in the air if it will come out.......I did not plan on taking this out again......my fabrication skills might have left no room to remove....:BangHead::BangHead::BangHead::BangHead::BangHead:
Seriously can’t just unbolt at the manifolds?
Morning cool down and windy here today and I think tomorrow. Tim, can you modify your exhaust with 2 1/2 collectors to drop out the center section?
Headers, shorty. That is not the issue....Trans has to be moved back to remove, just about an inch. locating pins. The Tunnel over the GV unit had to be modified, rebuilt completely, and there is not much room to the rear. We will see. Might be able to tilt the engine trans unit to remove,
The engine is already tilted down some, a few degrees, to get it to fit. Getting that GV to fit in this car was a big project...IMO
ohhh i didn't know you had a GV... yeah should be able to tilt it down way more then enough.. dont' forget to check fan to radiator space when you do it
Engine is already tilted, almost to the dist cap hitting, just to make install work....so............for sure will have to remove dist....
well.. pewp...
Agree. I installed everything as a unit from under car. Lifted and rolled unit in. Slick. Now I might have to reverse that process. Different kind of work.....Have to roll car out of garage because there is not enough clearance to lift car high enough in garage...
I would remove the dist cap or dist even if you have to and try leaning it back a bit.. could also just loosen the k-frame bolts to give it a little more tip to clear.. only takes a little in the front to drop that back a lot
Could you leave the whole thing bolted together and simply drop the k frame and lift the car off of it
Of course the gear wrench I'm missing is the one I need
9/16
