Stop in for a cup of coffee
Always try to get the sales on these. Regular prices are nuts. Looking at the original $419 on the 2nd one, that would be comparable considering it only has one battery which is always a huge factor in cost. I have M18s and for those they will try to trip you with '2 batteries' being one good size and a 2nd of much smaller Ah.
Indeed
I have a 5, 3 and 1.5AH batteries for my set. I could use another 5.0
So grabbed pellet food for the koi.
And a few play toys for my 4 legged Buddy.
Ok boys and girls
Sitting here thinking... Which is dangerous
Pulled that patch off the drivers floor. 36 sheet metal screws and who knows how much adhesive.
It's kinda ugly, but I think manageable.
Glad I pulled it off. It was rusting still and the frame extension was full of dirt.
So.... What next. I think I can get away with a patch and it'll be less complex than a full floor pan.
Can you order 1/2 a pan?
Thoughts?
Ok boys and girls
Thoughts?
that's not too bad... clean the inner part of the frame.. i would corroseal it then paint... then make a patch...
if you had a bead roller it would be nice to add some lines for strength.. but with the frame right there.. meh... even if you did that in 2-3 pieces to make it easier it would be ok
btw.. when you cut out the old ****.. cut 1" more than you think you need to.... trust me.. i cut too short on all my **** and spent time welding to rust... can't really use butt and cut on that.. i keep big sheets of project paper to make templates from
Yes. Giving myself some playroom. I'll see how far it goes when I start removing the rot. There's some spot welds I'll need to grind out
yeah when i got my car i had to fix spots over the frame like that in the trunk.. ended up cutting up like a foot more just to clean the frame and paint it... long air hose and shop vac helped to clean it out
mine had old scale rust completely packing the inside on both sides... luckily still pretty solid and saved it
