Good idea thanks Dave.Fred, put some vacuum hose on the bleeder and put the other end in a bottle with about half full of brake fluid. Fill the master cylinder and pump the brake slowly. It will push air out and suck fluid back in.
I have a rod/pedal pusher that works well. But lots of trips to reset. Better than a helper that wont fn listen.Fred, put some vacuum hose on the bleeder and put the other end in a bottle with about half full of brake fluid. Fill the master cylinder and pump the brake slowly. It will push air out and suck fluid back in.
Yea like working on a farmer's work truck with a gun on the seat and ammo all over the inside and empty beer cans scattered all over the cab. HO! and mud caked all over the undercarriage. Yea I'm done with that.I have seen a couple dirty/gross vehicles. Turned em away. One i should have, 1 year old and interior was trashed.
Lucky me the owner of the truck is a friend and if he screws up I can yell at him.I have a rod/pedal pusher that works well. But lots of trips to reset. Better than a helper that wont fn listen.
Two trucks, hole through floor, beside gas pedal and took a chunk out of bellhousing. Nother one,Dodge ram with a chunk out of passenger window post.Yea like working on a farmer's work truck with a gun on the seat and ammo all over the inside and empty beer cans scattered all over the cab. HO! and mud caked all over the undercarriage. Yea I'm done with that.
How's things out in the archipelago?@halifaxhops
Mopar Big Block Point type distributor - auto parts - by owner - vehicle automotive sale - craigslist
Think this one may have been posted before, not sure but this ad 3 hours old, not much info
#3, ex co-worker shot out passenger window, govt truck. They were working away,staying at a park cabin. Claimed he hit it with a log in the tractor grapple. I called BS, no glass inside. Not even a crumb. Co worker threw him under the bus. Brought his firearm into the park. Taboo. The fact that he was ****-faced came up in the conversation explains why window was still up![]()
Sounds like the same around here.Try me, hopefully it’s good newsOk. One of those days that was a huge day at work but really won't translate to anything others will understand.
Having a private party in my head
Bulkhead connector. Found a weak point. I thought you learned by now.Okay electrical geniuses…
Let’s say on a 64 factory wiring harness, you connect the ammeter wire ends together but your dumbass manages to let it touch metal and arch. Now no power, what blew? There’s no fusible link by the way
Oh this is me trying to fix the problem that I caused 3 years ago. Just now getting round to itBulkhead connector. Found a weak point. I thought you learned by now.
Start testing. Battery out.
Successfully obtained a top level DNS CName and Purchase Request line item went through approvalTry me, hopefully it’s good news
Yep bulkhead connector. More then likely...Oh this is me trying to fix the problem that I caused 3 years ago. Just now getting round to it
