Looks like a red fox. Black legs are a good clue.
We must be related as that is my great grandmother's sewing machine.I see my Grandma's sowing machine there
Yep I am not real sure why folks don’t can meat anymore. But we can everything! Best forum for canning is on FB called rebelcanning. We tried a brownie recipe and while I scoffed canning brownies they were actually very yummy! Once again for about the millionth time she was right and I was wrong!Oh man! What time is dinner?? It is that time-I need to inventory the freezer. We can a lot of the burger so it’s pre-seasoned and ready to go!
He demanded cash only. Should have been a clueI hope you disputed it with your credit card company
We got the same sewing treadle our machine has Sphinx graphic on it. I keep thinking we should restore it.
Congratulations to the both of you......Simone and are celebrating are 30th anniversary. Brunch at Tom hams lighthouse.
Congrats TimSimone and are celebrating are 30th anniversary. Brunch at Tom hams lighthouse.
Congrats guy,Simone and are celebrating are 30th anniversary. Brunch at Tom hams lighthouse.
That was the OE tank and gauge gone bad
My first cars were the "slosh and listen" type.I had to teach my brat to use the odometer and calculator as a gas guage when I gave it to her in '02That was the OE tank and gauge gone bad
When your car only gets 10mpg and your tank is approx 16 gallons you keep an eye out...My first cars were the "slosh and listen" type.
Bare. Clean it good for good seal...Filler neck inside the trunk painted or bare metal?
Congratulations to you both
Ooo shiny...
Congrats!Simone and are celebrating are 30th anniversary. Brunch at Tom hams lighthouse.
That's great, Congratulations!!!Simone and are celebrating are 30th anniversary. Brunch at Tom hams lighthouse.
I painted mine.Filler neck inside the trunk painted or bare metal?
Exhaust paint?I painted mine. View attachment 1716297534
This is why I have a manual ****Hi all,
I have a 1965 dodge dart gt with a rebuilt upgraded 318 and rebuilt 904 tranny. I got the car partially finished and had to install adjust, or repair just about anything to do with the operating controls, including installing an NOS shift cable, a Bouchillon kickdown cable kit, and the correct carb (edelbrock) linkage setup. The early a body leaves very little room to get to the area of the tranny where the kickdown band adjustment is located - as a matter of fact, I had to modify the Bouchillon setup to get it to fit (invert the lever ball, fabricate a shorter height cable end assemby). My question is this; the tranny shifts fine, but will not kickdown into second when the throttle is wide open, and yes, the butterflys are full open. The kickdown cable is correctly installed also. When I want to get into second I simple use the console shifter to downshift and all is good...all shift points are fine and no slipping that I can detect. Can I leave the kickdown adjustment where it is, or should I do a ton of work and tear up my arms more to get to it? What to you guys think?
Thanks,
Tom
