and we wouldn't want it any other way. Anal!
Could I solder in something like this?Now why wouldn't they make the rod longer with a bend in it, for some adjustment?
Well my Guage cluster is in the USPS Merry go round
Ohio to pa Philadelphia Distribution center, to Abington pa post office. That's 5 minutes from me.
Back to Philadelphia Distribution center.
@halifaxhops
Mike seriously it is easy take out the spring coil bend it open a bit more heat it with a torch like a Bernzomatic quench it reinstall you are done. Did it many times.Could I solder in something like this? View attachment 1716382972
I would cut off a piece and tap threads. Then it's adjustable.Could I solder in something like this? View attachment 1716382972
Good call.and we wouldn't want it any other way. Anal!
@halifaxhops
I gave that a thumbs up and changed my mind!![]()
Good morningThis one is hard as a rock.![]()
Just one big happy dysfunctional familyGood morning, don’t know if I should backread. Con-text the group hug?
The coil travel is good, the rod is too short. (que Karl)Mike seriously it is easy take out the spring coil bend it open a bit more heat it with a torch like a Bernzomatic quench it reinstall you are done. Did it many times.
It's hard to be good, but it's got to be hard to be good!Good morning
Isn’t that the way it should be?![]()
Too soft! Wont create morning thickness! So Karl said once!Oatmeal and coffee today for breakfast....................
That's what she said!Too soft!
Unless you're damn good!It’s no fun being good
Both my heads are thick 24/7Too soft! Wont create morning thickness! So Karl said once!
Damn good at being badUnless you're damn good!
And that’s a damn good thingBoth my heads are thick 24/7
At least you got nuts!
