Could be a small vacuum leak , spray something that will ignite wd carb cleaner around the carb base good, and allong intake runners at the gasket.. good luck, hope it's just a vacuum leak on the carbOk Bubbas...
The car moved under its own power... just up the lane a bit. Still trying to get the idle and ignition happy.. there is a pop_pop noise when in gear and idling
