Stop in for a cup of coffee
i like cutting my lawn ..cut 5 ac
its my me time ..have a 82" deck if i do it all and it grew a lot 5hrs ..normally 2/3 around the front,side ..do the back every other time
just bought a bat wing end of last year 11' cut ...hope to shave 1.5 hr but need to fix one of the lift cylinders before i can use it
About the same here,60” 3 point mower behind my little old Kubota diesel tractor. You are going to find the 11’ is going to shave a lot more than that off your mowing time. I used my son’s 10’ mower, less than 1/2 the time.
Good morning all.
Best price I have seen for insulation like that................however, long drive and a gamble for something that looks good in pics and may be total garbage from sitting outside for possibly years, mold, wet, etc.
Does seam like a great deal, but definitely want to be sure it will work. A lot of the old stuff is open cell and does absorb water. Cold storage dock doors were metal clad foam and would get so flippin heavy, springs couldn't be adjusted anymore and have to replace the door. That would be obvious just moving a few pieces. The raised patterns could make for a cool looking shop interior, (or could be a nightmare to line up in any way that made sense.lol) Even the ends of the full panels look like they might be patterns. Also, you could end up paying more to get rid of the scraps then the whole mess cost you...
Good evening all of you good folks in America. And good morning. Lynda and I are going out to dinner now. Out on the town..
Matts son has a cdl and a truck with a enclosed trailer. Semi-truck. Let me ask him how much to both of us. He parks it down the block. Want me to ask. Have to figure out what i need at least 30
Let me see if I can get my son to check it out.
I think it is best for Wolfies son to check first. I would need at least 80 depending on size...........
There was a guy in Somerset PA which would be closer but I cannot find his ad. That would be closer. How much are they asking per sheet?
I posed this question to Chris yesterday since he has similar wheels..............
The issue I am having with the front Cragar is that 4 lugs go on fine and 5th, doesn't matter rotating tire, etc. Washer will not sit flat on the face of the wheel always. I have to crank it on, shouldn't have to do that, just doesn't feel right. I wonder if the issue may be due to a larger hub from stock?
Lugs and wheels
Have to measure it again but 45x43 will cover it have to do the math. Some how coming up with 63 sheets that has to be wrong. I think when I did the math last time it was around 30.
Lugs and wheels
[/URL][/URL]
[/URL][/URL]
What pattern do you have on the car? Those wheels show 4.5 The washers with that lug kit are variable, but can only be used on wheels with the inset holes they drop into.
