Stop in for a cup of coffee
And its 4:42, morning!
A touch of frost and Kim is scurrying around while i sit on my butt surfing through FABO.
***** all packed, i forgot to fill up last night. Got enough gas to the to the airport so its all good.
I will keep y’all posted!
Good Morning All! Chev 305 here : )
You need this
so it's done?! :)
Yes, Sir!! He came over at 1620, and I was done by 1815. He was great. He showed me the first set of valves, and I did all the others. He also showed me a couple of different options for hooking up the bump starter. With the headers so tight, we had no access to the starter wires. Now I know how to do it, and I understand the valve's opening and closing positions for adjustment.
He also took a look at my front wheels, where I mentioned I was having issues with it sitting flat on the face to seat all the washers correctly. As you guys mentioned, the problem may be the wheel weights on the drum, BINGO, he showed me on the back side of the wheel where it is hitting.
