Stop in for a cup of coffee
Morning all.
I’m officially stumped.
The Cummins yesterday just miles from home on the return trip, started missing, back firing and basically acting like it ate another injection pump. Even through the dreaded 0216 pump failure code. I limped it home. Let it sit where died in the drive way at the farm. Hopped in about 5 hours later, it fired right up, runs like normal, runs strong, no smoke, no back fire, no 0216 injection pump failure code. Drive it around the country mile square, total of 6-7 miles, ran just fine. Mechanical gauges so good fuel pressure to the pump. Confirming the factory readings from the computer(separate sensors and locations)
wtf :BangHead: :BangHead: :BangHead: :BangHead:
Morning all.
Drop a LS in it!:thumbsup:
Man that sucks. I would guess you need it to happen to trouble shoot it at that time? No idea on them.
Same as usual so far. Going to try to get stuff where it belongs again. Takes forever alone.
Wow
They can go for big bucks
Wow
That's a bit of a stretch just for the tire.
Luckily I know all the drivers and the whole postal crew. Fed Up is still a mystery. Got a large manual the other day in the rain and it was left on the ground by the mailbox from Fed up. I was not happy, 1920's book and it got soaked! Same with 5 gallon jugs of simple green. Always left up there!
Luckily I know all the drivers and the whole postal crew. Fed Up is still a mystery. Got a large manual the other day in the rain and it was left on the ground by the mailbox from Fed up. I was not happy, 1920's book and it got soaked! Same with 5 gallon jugs os simple green. Always left up there!
Agree... Fed and the random DHL stuff gets slung all over the place. I tried putting a box out for them to put stuff in... but they just set the package on top of the box.
