Blucuda413
Planning on building a 360 street engine with a Procharger. Heads will be ported stock units with a blower cam which is probably bigger than I need. Probably will go with either a blo-thru carb or might even try a Holley FI unit. Basically I'm looking for a recommended compression ratio so I can buy pistons and rods. Thanks, Max
