jtolbert
Wow...That's harsh. Kroil works much better as a penetrating oil than PB Blaster does...Well worth getting some.
Ya think? How'd you come to that astute conclusion?
The easy way would be to just replace the LCA, but where's the fun in that? Burn the rubber bushing out so that the LCA pin will just fall out. Then take the arm to a press and press the t-bar out..........
Boy, you guys working on 30-40 year old cars in the rust bucket states here in America, i feel for you.
I don't see anything like that at all, being in California.
Sure is nice out west, in California, Nevada, Arizona, not having to deal with rust issues that your going through.
Wow, good luck with that project.
What year car are you working on anyway?
I have a rebuilt pair of LCA's, with sway bar mount tabs on them, for the 73-76 cars, currently listed on eBay.
Jim V.
gonna take Badart up on his offer but will a '73 LCA work on a '70 car?
Sure, any LCA from the 62-76 cars will interchange with one another.
I know the feeling. I started my wrenching career in Rhode Island and know what you run into. I think that even once you get the T-bar out of the socket, the rust inside the socket will probably flake out and make the hole too big and sloppy to reuse anyway. On a side note......I was standing outside the main gate at Quonset Point one day waiting for a ride when a Volkswagen Bug when blasting through the intersection. It was an intersection that has a dip going in and a dip coming out. By the time the bug was completely through the intersection, it was in 5 pieces! The engine/transaxle went one way, the front end another, the right door fell off along with a front and rear fender. After it slid to a stop on the pan, the driver got out, shrugged his shoulders, and walked away. It was one of the funniest things I ever saw. After I picked myself up from ROTGL I walked over and took a look at it. It was a wonder it made it that far without falling apart. Every part of the car was rusted through. The only reason the drivers door didn't fall off was that it was welded shut!Yes the retaining clips from the rear anchor were removed. It's all outside the car I just have the LCA sitting on my garage floor next to a broken vice and a hammer, with a torsion bar stuck in it.
Tried using a little bit of heat as well, no such luck.
Considering securing the LCA to a tree and strapping the end of the bar to my truck. :happy1:
