Stuff I do while Truckin
Dookie trailer from okc tAustin
Came across the Guadalupe National park to get to El Paso.Im at the Petro till Monday to pick up a tank or rocket launching simulator going to Minnesota!
Well.Im Broke down.The trailer has a airbag king pin and the bag burst.Im in Almagordo Nm.Its a square one and the shop cant find one yet!when we loaded the was 18 of us!
Man you are having my luck! Just had track off dozier because of broken axle shaft in idler and broken yoke. Ran it three days and now final drive seal is leaking on same side so going to take track back off and pull final drive. Probably wire wrapped around and tore seal. Good luck and stay safe, Joe
Dammit
Had to re adjust a Moffet.The rear tire was about 3 inches off the ground.It wasnt python the trailer properly and the trailer is missing a pad on the rear for the moffet to rest.Its metal to metal right now but the tire is 8 inches off the ground!St Paul to Denver by Aurora
Went to Dallas and picked up a pos junky reefer and took it to Indianola Missasloppy and now in Paragould Ar picking up a trailer for Penske in Waco aka "We ain't commin Out"in the mornin
Tony, google Incredible Hulk Cuda and watch his you tube video. He is staying here at Hard Rock and has it parked close to mine. If you haven't seen it, it is absolutely incredible. We talked a lot and really nice people that like to talk about it and not brag. Wish you could see it in person, Joe
