skep419
5.9 Magnum 4 speed afficionado
69 dart 360 ede heads,voodoo 60403, speed pro 416 Pistons,scat i beams, ede air gap, 750 Holley dp.
4 speed cf dual friction 2.66
8 3/4 3.91 have a 3.23 set up that I'd like to swap soon.
Car runs good. But I recently swapped cams so I thought I should check the cranking compression.
It's now at 200.
I've been running 91 for the most part but put in 87 without any issues (haven't felt any pinging) when 91 isn't available.
Initial is at 20 with 34 total. It comes in fast and I'd like to get aggressive with the vacuum advance if I could find the right can.
It's now at 200.
