superstock springs rear clamps?
I hate to add fuel to the fire. But this is what I run in my demon it works great super stock springs solid bushings clamped front sides of the springs clamps removed on the back 2' axle wedges bolt on traction bars set 1/2" under front bushings adj pinion snuber set 1" from the floor with air shocks set @75psi plus sub frames torque boxes perch re forcements 90/10s up front as well as solid motor mounts. The set up is based off the suspension of my fathers record setting Plymouth duster that he campaign in the 70s it might sound like over kill but it worhs and works well
