MOPAROFFICIAL
Oogliboogli
That way from the factory .
The rear spring hangers you are using need to be swapped back to the original hangers. While you are doing that, wire brush, lubricate and loosen the u-bolts that hold the rearend to the leaf springs enough so that once your hangers are back in you can nudge the rearend towards the driver's side of the car.
The purpose of this is to shift any slack in the fitment of the springs and the rearend as far away from the passenger side of the car as it allows. Then retorque your u-bolts and re-check them a few times to ensure that they are maintaining the torque. If there was any play or movement there, it will be towards the direction you need the rear end to be.
I had the same issue on my E-Body due to running 325/50-15's on 10 inch rims. I also carefully ground about half of the fender lip off at the top of the wheel well lip using a wet cloth to avoid building up too much heat that might harm the paint. I blended the relieved area in to make the area I removed less noticable.
The car may not be square to start with. Factory quality control wasn’t around. The change in clearance is odd.
Double check the attaching parts to the spring again.
The S/S springs are designed to have that funny tilt for racing purposes.
ok, maybe 1.5" was a bit of an exaggeration, but it is off enough to cause a problem. View attachment 1715497572 View attachment 1715497573
Those Radial T/A's are a stiff sidewall. the picture looks like it has room. is it hitting?
if not...i had much less room that that with T/A's on my dart for years. (or at least what it looks like you have in the picture) i literally had maybe 1/8 of an inch. those sidewalls dont flex at ALL.
That is VERY common on these cars. I'm not sure where the variable is, but precision was not job one.
that looks like a normal case of tolerances stacking up against you
ps Also when you're all done take it to a good alignment shop and they can tell if the rear end is straight (it probably is) and it will be worth it as they will have it all squared up. Before you take it there lube the *** out of the upper control arm nuts and you can put a wrench on them just to break them loose and tighten them back up. Just make sure your tie rods and idler arm looks good also as they will not align it if everything is loose. Idler arms are always a issue on these cars. And always burn them up and have some fun.
Just curious, but won't you have to make sure that the driveshaft isn't at an angle to the trans. from the rear?The rear spring hangers you are using need to be swapped back to the original hangers. While you are doing that, wire brush, lubricate and loosen the u-bolts that hold the rearend to the leaf springs enough so that once your hangers are back in you can nudge the rearend towards the driver's side of the car.
Yes move one thing and it can have a domino effect. It depends how extreme you want to get with it. Usually it's about a 1/4 inch or so and I really never had any bad vibs or anything by moving it this amount. Now if your running slicks and have 500 600 horses or so everything should be correct.Just curious, but won't you have to make sure that the driveshaft isn't at an angle to the trans. from the rear?
I agree, thanksYes move one thing and it can have a domino effect. It depends how extreme you want to get with it. Usually it's about a 1/4 inch or so and I really never had any bad vibs or anything by moving it this amount. Now if your running slicks and have 500 600 horses or so everything should be correct.
Frankly, moving it(the rear) towards the drivers side may actually correct it (driveshaft angle)because it may have been at an angle while the whole thing was shifted to the passenger side. It would be interesting to know the result.Yes move one thing and it can have a domino effect. It depends how extreme you want to get with it. Usually it's about a 1/4 inch or so and I really never had any bad vibs or anything by moving it this amount. Now if your running slicks and have 500 600 horses or so everything should be correct.
Slot the holes on your spring perches and slide it over 1/4”.
Want there some sort of offset bushing or center bolt?
I though i saw something somewhere.
Or hole in perch oversized? And shifted..
Probably not, but as you may know, moving a 1/4'' at one end could be 3/4'' 4 feet away and I'm referring to side movement. I'm just thinking out loud.The shift to the right is way less than any up and down movement that the rear end during normal driving.
So I doubt that is an issue
