forced 340
Hey gang! Has anyone run T&D rockers on their trickflow 270's? I'm not sure what offset to get. I'm thinking .650"?? Thanks for any and all advice!
Trick flow runs mopar standard rocker arms. Eddy run off set rocker arms and indy.how was I confusing heads? I asked about trick flow 270's. I am going to run them on my build. I can get a set of t&d rockers from a friend of mine and wanted to see if they would work, or if anyone has run them. T&d does not list a set just for trickflows.
I have my custom rockers for the Trick Flow heads, and made by T&D, in stock. They have better geometry than the "off the shelf" rockers. If you're going to spring for a quality rocker arm, you might as well make sure it's the best it can be.
I tried to send a PM, but your inbox is full. Email me at contact@b3racingengines.com and I'll get back to you.Price for 1.5 trickflow 240's ?
