scampman416
Some of you might no, but this is my knew R3 engine, in my 71 Scamp 4 spd car 416 cubs indy heads, 360-2 cnc ported built by rayanj indy intake 1.65 T&D rockers, bullet cam, 700 lift 11.30 comp Diamond pist,scat pro comp lightweight drag crank, 8" adj Advanced clutch ***. clutch and flywheel 25,lbs 4:88 gears 30" x 13.5 DOT M/T E/T radials. No dyno but I'm guessing 600 Hp to the tires Car is 2900 wet me in it. I also have a 250 shot nos for it but have no planes of using it yet.Tube front end coil over, Ladder bar rear, coil over.
Whats it going to run ? check out the video The shift light is set at 7000 RPM
[ame="http://www.youtube.com/watch?v=6bGQlZhqS-w"]YouTube - ‪71 Scamp ,650 Hp Small Block, 4 spd ,Test drive.‬‏[/ame]
