OK, I found it. The wiper switch/motor is the problem. Disconnected that, and now no more excessive current draw. I noticed it when the amp meter was hooked up, and I turned the ign sw on, it would jump all the way to the left-discharge. So I took the wires off the amp meter, and when I touched them together with the key on, it sparked alot. Also put a test bulb in series there, and it got really bright. So the wiper switch and motor is shorted to ground. Re hooked the wires to the ammeter, and it barely moves to the left now, when you turn the ign sw on. Had I left the key on, with the wiper motor hooked up, I'm sure we would be seeing some wires smoking! That's what I like about the ammeter, it gives you an immediate readout of which way the current is going, and how much. Whew, Dodged a bullet there!
