Inertia
I did take pics but they may be lost in Myspace somewhere.... There is definitely a difference in the 3.55 and 2.45 carriers but if the gears are matched with the correct carrier you should be good to go. I used the same shims from the 2.45 pinion and it set up fine with the 3.55.
I woulda bought a lottery ticket that day. The odds of the same shims even being close is amazing.
