Thoughts on fuel economy
rbkt65
jerseyville, illinois.
I am putting a magnum in my 71 Dart, not sure if 318 or 360. It will have the complete fuel inj and 46re, dana 60 with 3.54 gears. I have changed the cam in the 360 to the 318 cam as it has more lift and duration, per the fsm. I will be using a 360 pcm. Any thoughts on the difference in fuel economy between the 2 engines? If only 1-2 mpg, I will use the 360. If 5 or more difference, I will use the 318. I know it may be a loaded question, but this will only be a cruiser. Tires size will be 275-295, if I can fit them under after moving springs inboard. thoughts are always appreciated. rick.
in my 92 2wd Ramcharger the 5.2 would max out at 18-19mpg 3.55/518 and i'd get mid 16s max with the 5.9. both stock. So yes its going to be a couple MPG difference, I have no idea where you'd end up in a dart, but I certainly wouldn't loose any sleep over it and build the 5.9. I think i have some manifolds and heads (probably cores/used to be good 10yrs ago) you can have if you ever make it over to Springfield
If you care, that is fine, but I am not at all concerned about gas mileage. I have a 69 Barracuda with a moderately built 340 (about 375HP), 4 speed, headers and 3.55 gears, and I don't lose any sleep over gas mileage. My 340 is a blast to drive, and it sounds great. I figure that if I am going to worry about a few dollars a month, I might be in the wrong hobby.
You said it will only be a cruiser. That means maybe a tank or two of gas a month??? 5 MPG in a 16 gallon tank will be maybe 30 or 40 dollars a month. I would build the car however you want. Do you want the power potential of the 360, then go for it. Like @Trojmn said, don't lose any sleep over a few miles per gallon.
If you really care about mileage, keep the 360 under the work bench. I don't think about mileage. I think about fun. Will the 318 make you rich with left over money? No. But that warmed up 360 will be WAY more smiles per gallon. If that's not why you're in this hobby, then, join a Prius club.
I don't know what you drive but as long as you're having fun.
Gladys is the old adage "a 3/4 truck on a one ton chassis". I figured mileage......sorta on her once. It started with a "1" so it was gonna be double digits. I'm happy enough whether it's 10 or 19. LOL
I daily drive a Durango with a 360. All stock except eq heads. 3.55 and 265/70-16. I don't care his I drive it I get 13.something. driven 70 miles a day. The best mileage I ever got with a magnum was my 93 318 Dakota that I converted to a stick. I had no problem getting 20 out of that one. I wish I still had it. The difference between 13 and 20 is enough to be noticed with the amount I drive. But the Durango has 320k on the body, about 130k less on the motor... And zero payments
Here is what I have on file for Factory Magnum cams; first the 5.2M, and
following that, are the worked out durations from the various events. Up first is intake, then compression, then power, then exhaust. Then; overlap, Lsa, and finally lifts.
1) 251/125/111.5/264/31.5/113/ .432
2) 249/131/112.0/269/41.0/109/.410/417
If these numbers are correct, then;
IMHO, not a chance would I install the 5.2 cam for fuel economy.
>The following numbers are when installed at or near split overlap.
>The Ica of the 5.2 is 6 degrees later, which will drop the cylinder pressure of a 360@9.2Scr, from 167psi (5.9cam), to 159 (5.2 cam); both at sealevel.
Pressure is heat is torque, and times rpm is horsepower.
That's 8 stinking psi, or about 5%. This is torque you can feel ALL thru the rpm band, whenever you roll the throttle on. This is like changing the rear gear ratio, a half a size.
>On the other side of the coin, the 5.2 cam has just 31.5* of overlap, versus the 5.9 @41.
Now, if you run log-manifolds, this means nothing to you, cuz logs kill the overlap cycle.
But if you run headers; this is a full 10 degrees more, or about the same as 1.5 cam sizes ...... which will make a nice little bump in horsepower up higher. It
has the potential, with headers, to eclipse the 5.2 cam in power, in spite of the lift difference.
>Now, one place economy is made, is in the power-extraction, and in these two cases 111.5 versus 112 in miniscule, so as to the POTENTIAL for economy, that spec is as good as the same.
>As to intake duration,
the 5.2 cam has 2 degrees over the 5.9, which in your case means nothing, whereas
>as to exhaust duration,
the 5.9 cam has 5 degrees over the 5.2, again, meaningless to fuel economy.
Between those two cams, I'll pick the 5.9M everytime;
More torque, more power, and has the potential for more fuel economy.
the smaller lift spec, in this case, and IMHO, is almost negligible.
And the bonus is that with a 20 degree spit between intake and exhaust durations, and especially with log-manifolds, you can play with the tune even more.
Happy HotRodding
EDIT
If you put a healthy 5.9 in that Dart, with either of these cams, and end up with about 160psi, with a tight Quench, it will gave you GOBS of bottom end torque.
If you really want economy;
>You can run a Mopar, A833od.
The ratios are;
3.09-1.67-1.00-.73 od.
That torquey engine will run down the hiway easy enough as low as 65=1600; which means, that you can run a 2.76 rear, for a final drive of 2.01; I know because I tried it (1.97 ratio).
Your starter gear of 3.09 x 2.76= 8.53, which is the same as running 3.23s with a standard 4-speed. No, this will not set you back in the seat, but you said she's a Cruiser.
Second gear is 1.67 x 2.76=4.61, which is like Third gear with that 3.23, so, you kindof miss having a Second gear.
Third is a straight 2.76 for 65=2230, already pretty low, and a good gear for max fuel economy because ..... you can actually set the ignition timing to optimum. In this case, at 65=1600 (with the 2.76 x .73), it will be impossible to set the cruise-timing to optimum with the factory ignition system, so you'd always be leaving a bit of economy on the table.
However, same gears get you 85=2130, where you may indeed be able to get the timing optimized. This means you effectively have two hiway gears, one reasonable starter gear and no second.
That's just one option.
From here, it just gets better.
If you're willing to give up that Second hiway gear, for more Second gear for instance, you could do the math with say 3.23s or 3.55s. All you lose is the high speed touring, but even 3.55s , make 75=2420, and that for sure can be fed say 56* of cruise timing. And 3.55 x 1.67= 5.93, a reasonable Second gear.
If yur strictly an automatic guy, the Mopar Overdrives offer excellent ratios, and .69 overdrive, that when used with a Lock-Up, can get near manual-transmission results.
>With an A500/518, I'd be tempted to run the 5.2M, cuz, with a Torque-Convertor, you don't need the bottom-end torque of the longer stroke/bigger bore; 5.9M
In this case, I'd go with the A500.
If I had a stall choice, in a LU convertor, I'd try a 2400, with 3.91s. or
2600 with 3.73/3.55s; or
>2800 with 3.23s, but with this gear 65=1800, which, because of lack of optimized ignition-timing, may not get any better fuel economy over 3.55s(1980rpm), or 3.73s(2080)
All numbers listed are with 27" tires.
Personally, I really like how a 2800 works with 2.76s. I can't really describe it, but I really like it.
By itself; 2.76s will get you 65=2230
I never really found this doggie with the 2800; not a powerhouse either, but:
All I could get out of my ignition was 46* of advance and the engine wanted, 52>56. So I bought me a dash mounted, adjustable, Timing Module, with a range of 15 degrees; problem solved.
Another datapoint:
67 Barracuda
5.2L magnum with stock injection
AX15 5-speed trans
3:73 gears
On the highway it got about 22 mpg
Plenty zippy with the rear gear
Do you plan on driving it enough to matter much ?
Is 20-40 more gallons (whatever it is) a year really gonna make that much of a difference ?
My only concern in fuel mileage is how likely are you to get from the two closest gas stations in the farthest stretch you plan to drive…
Example: I plan to drive it 40 miles, but the two closest stations on that drive are 30 miles apart.
Wow. if you are concerned about gas stations being 40 miles apart, you are getting lousy gas mileage.
:rofl::rofl::rofl:
A wise man once said "Fun=Money !"
That was ME! I said that first in 1986.
We put a 5.2 Magnum with the overdrive auto into a 1984 Ramcharger. Got 17 mpg on the highway when we were done. My 2000 5.9 Durango (heavier) gets 17 mpg on the highway. I really doubt you will see much difference, but mileage should be better in the lighter car.
How do you get 17 out of the Durango? I have an 01, also 360, 13-13 1/2 is about normal for it... Is yours 2wd. 320k miles,
(Has a 2000 engine now, had to replace original engine at 260k... Current engine has about 130k less than the body). All stone stock except for Out of the box EQ heads and 1.7 roller rockers.
My 5.9l jeep got 13 mpg intown, don't know about highway don't use it much.
2wd. 3.55 gears. 11 or so in town. Always get 17 on the highway unless we're towing with it. Cruise control is always set at about 70 unless towing. The new Durango ('17 Citadel 5.7 and loaded AWD) got 17 towing the old Durango home on the flatbed car trailer with the cruise set at 60 or so.
I swapped a stroked 5.9 Magnum(408) in place of a Slant 6 about 10 years ago. The 408 got about the same mileage at 70 MPH (17MPG) and around town (14 MPG) as the Slant 6. The Slant didn't have overdrive or EFI though, and was a DougDutra built motor with a 2bbl, his exhaust and smaller of his two cam profiles.
The Slant 6 was a good running motor, but no where near as fun as the V8. This was with light throttle, top down 3.55 gears and 28 1/2" tall tires.
I've also got a d150 with a fresh/6 in the other side of my garage, have the 60s era /6 to SB trans Bell housing adapter plate on hand, have to finish building my a500 that's been apart for too long to put back in there in place of the original leaky 727... it's built up a little... Big valves, mild cam by Oregon, super 6 with 318 BBD, hogged out exhaust manifold.... remains to be seen how that one will do. That one is intended to be my 3 season daily driver as soon as I get the dash back together (adding all the parts for factory installed AC) and get that a500 in there.
I need to slow down on driving the 360 Durango as it's supposed to be my backup, only because it can hold 2 car seats for the grand kids.... But I've been daily driving that since my son put the plow on my 96 Dakota...m trying to keep some miles off my 12 so I can get some semblance of decent money for.... It's going away once i get the 85 done and my 83 done .. then I can park this Durango for the summer.... We still have my wife's Durango but it's only got the (ugh) 4.7....
Nothing wrong with trying to maximize mpg . More range and less money spent . I use my Barracuda as a daily driver and with the 360 ( pig rich ) and 2.76 gears I got a best of 16 . Tat is with a 221/229 cam with .550 lift on a 112 ( Oregon cams ) .
Now I am finishing up an upgrade to a 4” crank and a 518 OD . I would like to see close to 20 after jetting and ignition tuning . Might be a pipe dream …. I plan on driving it cross country and mpg matters .
There’s nothing wrong with trying to get more mpg, but a lot of the times it’s not cost effective especially for a summer toy that people don’t drive much.
I beg to differ.
If yur only targeting a couple of mpg, ok sure, I get you.
But why settle for sub-20s mpg, when it only takes overdrive to pump it up to, in my case, over 30, in point to point cruising. My GVod paid for itself post haste, and my engine has saved 28% wear over the first 100,000 miles that it has been idling down the road.
Cutting my fuel bill in about half, means I can drive to more places and further away, with the money that I saved. Plus it paid for my alloy heads real quick.
2mpgs is chicken feed. Aim higher.
