Throttle cable question
purplescamper
scotrun pa.
is it suppose to come apart like this ?
As above...........and.
It appears that cable is in the full/ nearly full throttle position, is the carb throttle closed, as it looks?
The metal tube section next to the clamp is supposed to be held under the clamp as Rusty say's and that little finger on the clamp section that points down is supposed to be straight away from the cable.
From the looks of it your throttle may not even be opening all the way.
Then again it might have to be like that due to a carb swap while still using the stock bracket.
