watso76
Active Member
I'm at a loss on how to adjust my timing. I have a stock 318 in a 76 scamp. I just got my carb tuning issues figured out but I need to adjust the timing to get it right. How do I go about doing this?
To get to the bolt holding down the distributor it helps to buy the special U-shaped wrench just for that purpose otherwise it's tough to get a wrench or socket on it.
Another point, you may also want to check the vacumn (yes the spelling is correct) advance to see if it's actually working. The backyard mechanics way is to just pull the advance hose off & on while at a fast idle. The engine should respond appropriately.
I can't find this bolt to adjust timing. It wouldn't be a set screw on the side would it?
