68383GTS
I have a 74 318.It has tiny threaded holes under each exhaust port.What are these for and do I need to block them off if my headers do not cover them?
Tap them, put in 1/4" x 20 set screws with Loctite and be done with it.....
Yup. Done that a couple of times.
You don't even need to tap them all the way into the ports. I just get some short set screws, tap the holes about half way through, and run the set screws in until they bottom out. That way the set screw can't possibly migrate into the port. I still use a little loctite to seal them in. Just make sure the set screws don't hang out and interfere with the manifold or gasket, some of them can hang up on the exhaust manifold flanges depending on what manifolds you're using.
Some of the ones I drilled and tapped were already plugged with carbon, which is what will happen to any space left between the set screw and port eventually.
oh boy! Not in to the head porting 10 minutes and broke of the taping bit in the second hole:banghead:
When i grabbed the heads from the shop (all disassembled and cleaned up) yesterday. L thought the welding idea was a fast and good one! ? When i told ted at the machine shop he gave me a little look and said he"i wish you wouldn't":color: So before i started on my first time at porting i wanted to plug the little holes. I broke the 1/4 inch threader of in a little hole:violent1: I had no problem with the other three on my first head. So now i really want to just weld over that little piece that's broken inside there because it's made out of a hardened steel. I can't seem to drill out for an easy out. Any suggestions?#-o
Grind the broken parts down and fill with some JB-Weld.
what is the casting number of those heads? They are probably 302's which are good heads.
Swirl ports!
Tmm
