Tires
You're going to have to give us more to go on than that. What wheels are on the car now? Are you keeping them? That would be a good start.
Haha i messed that one up i will have to look in am. But we are going to keep what came with car i need to load up some pics.
On my 72 swinger i had 225/60r15 on 15x8 inch rim with 4.5 inch backspace, after mini tubs and spring relocation 325/50/15 on 10 inch rims with 7 5/8 backspacing.
So i got 205/75/14 fronts and rear is 205/70/14 is what came on the car want to go a little bigger in rear but not too much
14” tire selection is weak these days. If you want slightly bigger I’d stick with P205/70R14 front and use a P245/60R14 rear. This staggered look will be nice and the two sizes have essentially the same overall diameter with the rears being only.2” taller so the ride height will look proper as well. You’ll need wider rims for the rears, I’m assuming you’re probably putting an aftermarket mag on the car? If you’re not and you are planning on using the OEM wheels I’d just stick with the P205/70R14 all around.
‘BFG Radial T/A has all these sizes available to you.
Exactly. If you have the factory wheels you really can’t go much wider than the 205’s you already have because of the narrow factory rims.
I’ll add that if you have aftermarket wheels you can run up to a 245 in the back if the backspacing is correct. That will depend on the axle that you have and its bolt pattern/brakes. A ‘75 should have a 7.25 or 8.25, which are the same width, but your ‘75 could still be SBP if it’s drums all around or BBP if it’s a disk/drum car, and that does change the backspace needed. And of course, someone could have swapped something out by now so it’s always good to check. 7.25’s get swapped out all the time.
Thank you so much yes going to stick with OEM for now. But i got plans for the car next yr.
Up front is 205/70-14's on 14x6 Vintiques Rallys with 4" backspace.
255/60 15's on the rear on 15x7 Wheel Vintiques with a 4.25 backspace. No mods other than a extra leaf added to the stock springs by the previous owner. No trimming or rubbing but they are close to the lip on one side.
Now i really like that. Mite have to change up rims
I had 14" Rallys all around and wanted some bigger 15's. I bought some, mounted them and liked the look. Of course I had to buy a new pair of wheels and tires to match. :BangHead: :BangHead: :BangHead: :rofl::rofl: Here's when they were all 14's. The tires were some oddball zized 75 series of Uniroyal Tiger Paws that I couldn't match.
