Wvbuzzmaster
This will be a quick opinion thread, as I am debating a manifold change... quick backstory. If I didn’t already have to pull the intake to replace the lifters I wouldn’t be considering changing the current Edelbrock Performer intake, because the trouble of changing it would not be worth it for the insignificant gains I probably won’t feel one a cruiser car. However, since I had inclination to change it before and now have to have intake off... should I change it?
I know this intake topic is beat to death so intend of asking if an intake is better, i already know going from Performer to Performer Rpm is better, and Air Gap is better again. Also know about LD340 is good and in the range of the RPM. So since car is going to be Spring to fall and I do have factory X heads... I am going to stick with an intake with the heat exchanger passage. So that limits me to three intakes, current Performer, Performer RPM, LD340, and I only own one of these three intakes already.
Quick specs and some of these will be close enough since I did not build the engine:
340 with forged crank and forged 10:1 pistons .030 over (nothing special)
Mopar purple camshaft, 284 advertised duration, 484 lift, hydraulic flat Tappet
Edelbrock 750 which may change to AVS2 650 soon
Changing from Hedman long tube headers to TTI shorty headers (wanted more clearance around things in engine bay/steering parts.)
Rebuilt X heads that are most likely just stock freshened, but was told had been mildly ported, which who cares...
talking engine probably makes best guess around 400 horse tops, never dynoed so basing on similar builds and dyno simulator program estimated around 350 horse.
Oh, still have stock torque converter on the 727 trans and a 8-3/4 with 3.91 gears. I know I would benefit from higher stall converter but not going to happen right now.
Going to make this a poll. I don’t want this to become an argument over numbers, cause I am not drag racing, I am back roads driving the car, so flow numbers are cool, but I am seat of the pants performance on this car... and knowing new carb vs new intake I am spending $400 each, do I skip intake and just get the improved carb because changing intakes won’t see as big of a difference? Or will changing to a dual plane with intake runners that are not T intersections a benefit even with better carb for seat of the pants feel?
