To Vacuum Advance or Not to Vacuum Advance
Fuel and Air Systems
  1. mopardude318
    mopardude318 Well-Known Member
    9,428
    545
    Jan 7, 2005
    Gilroy, Ca
    Local Time:
    8:27 PM
    Wow... you guys really got me wanting to change my mechanical advanced MSD distributor to a vacuum advance one. Had no idea there were that many benefits. Lol.
    Now the question is which one do I run for an aluminum head, large cammed hydraulic roller 408? And what would be compatible with my MSD Digital 6+ ignition box?
  2. 512Stroker
    512Stroker We are all here because we are not all there.
    597
    255
    May 30, 2016
    Freedom, MO
    Local Time:
    10:27 PM
    That is what I did, got rid of my MSD for a FBO distributor. Give Don a call at FBO he will curve one for your engine. The distributor he did for me with a vacuum advance ran great out of the box. I do believe you can run your MSD box just make sure you ask him for the correct cap so you can keep your current spark plug wires.
    • Like Like x 1
    • mbaird
      mbaird mbaird FABO Gold Member
      4,714
      1780
      Dec 10, 2005
      boise, Id
      Local Time:
      9:27 PM
      I found a youtube vid of a vacuum gauge thru the 1/4 and the vacuum built as RPMs built thru each gear and was up to 6”s as he
      ran thru the traps .
      I will try to find and link it.
    • yellow rose
      yellow rose Doctor of Thinkology.
      17,253
      13413
      Jun 19, 2015
      Living on the razors edge
      Local Time:
      8:27 PM
      What????? That means the carb was too small. Or something was seriously wackadooooooooo.
      • Agree Agree x 2
      • Like Like x 1
      • AJ/FormS
        AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
        16,271
        5046
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        10:27 PM
        I'ma thinking it was calibrated in something other than vacuum
      • mbaird
        4,714
        1780
        Dec 10, 2005
        boise, Id
        Local Time:
        9:27 PM
        It was a vacuum gauge.
        . It may have been due to a restriction such as a small carb. But most of us run a carb smaller than the max the engine can handle on our street/ strip cars.
      • AJ/FormS
        16,271
        5046
        Jan 19, 2014
        Local Time:
        10:27 PM
        reads more like CC-pressure. If you find it, I'd like to see that phenomenon.
      • mbaird
        4,714
        1780
        Dec 10, 2005
        boise, Id
        Local Time:
        9:27 PM
        I can find it on my smart TV in youtube but not on my phone to attach the link.
      • Mattax
        Mattax Just the facts, ma'am FABO Gold Member
        6,953
        3931
        Feb 7, 2013
        Phila. Pa
        Local Time:
        11:27 PM
        That or restricted intake class.
        I always think circle track for running restrictor plates or spec'd 2 bbl carbs, but could be drag racing too.
        There are (or were) some NHRA stock classes where 2 bbl 273 B-bodies fit in. R Stock, T Stock? Something like that. A coworker and somewhat of a mentor when I first got into this stuff had run in it. Claimed to have held the national record for a while, and I believe he did.
      • mbaird
        4,714
        1780
        Dec 10, 2005
        boise, Id
        Local Time:
        9:27 PM
        Here is 3rd gear...
      • mbaird
        4,714
        1780
        Dec 10, 2005
        boise, Id
        Local Time:
        9:27 PM
        He had his foot into it for 10secs so it was a fairly fast car.
        • Agree Agree x 1
        • mbaird
          4,714
          1780
          Dec 10, 2005
          boise, Id
          Local Time:
          9:27 PM
          The whole point of this is... can Vac Adv help in dragracing ? And I think that with many Non Maxxed out street/strip cars it very possibly could.
        • Mattax
          6,953
          3931
          Feb 7, 2013
          Phila. Pa
          Local Time:
          11:27 PM
          Its definately worth the discussion and investigating. I need to pencil in trip to a drag strip. I was planning to go when my mechanic gets his Omni done. That will be with a 3310 '750' frankencarb on a 340. But after that, I have a 650 vac secondary that I want to retry. So that would be a pretty good typical enthusiast carb/engine combo.
          Can't help on the youtube link. Simple code like Html or I get lost.
          Any other info on the car? Little air cleaners?
        • mbaird
          4,714
          1780
          Dec 10, 2005
          boise, Id
          Local Time:
          9:27 PM
          That was the only shot in that Video. He has others and it might be a Mopar he is running. Maybe a Magnum?
        • AJ/FormS
          16,271
          5046
          Jan 19, 2014
          Local Time:
          10:27 PM
          Wait; it idles at like 2" vacuum, and when he shuts it off, it's still at 2" vacuum. I'm skeptical as to what that gauge is actually measuring; I mean where. It doesn't seem to be intake manifold vacuum; the gauge acts more like it's hooked to a cc evacuator system, or IDK the fresh-air intake, ahead of the supercharger.. IDK but I doubt it idles at 2 inches
          • Agree Agree x 1
          • mbaird
            4,714
            1780
            Dec 10, 2005
            boise, Id
            Local Time:
            9:27 PM
            I was thinking it might be hooked to ported vacuum and the needle was resting until he hit the throttle. But something does seam off about it.
            Someone needs to video their gauge.
            • Like Like x 1
            • mderoy340
              mderoy340 Well-Known Member
              2,099
              818
              Aug 2, 2012
              Melbourne FL
              Local Time:
              11:27 PM
              My 340 immediately goes to zero and stays there until I lift. I run vac on ported and leave it hooked up at the track. 9" at idle in gear, 11" at 2k launch, vcan set to move at 10"
              • Like Like x 1
              • Thanks! Thanks! x 1
