JefftheComputerMan
:banghead:
Ok got THIS IS A BRAND NEW RADIATOR: Champion brand
PART #CC64DT
ALUMINUM CORE WITH ALUMINUM TANKS
NO EPOXY. ALL SEEMS WELDED
DIMENSIONS:
CORE: 16 1/4 TALL X 18 3/4 WIDE
OVERALL: 21 5/8 TALL X 22 3/8 WIDE
UPPER HOSE CONN: 1 1/2-OFF CENTER
LOWER HOSE CONN: 1 1/2-DRIVER SIDE
THREE ROW CORE--2 1/4 THICK
TANK THICKNESS: 2 1/2
No leaks anymore, removed thermostat.
It runs over 200 and it's not even hot here yet!
fixes attempted:
Replaced radiator.
removed thermostat.
replaced distibutor with stock 318
(this dropped temp from 230-240 to 20-210)
replaced sparkplugs and wires
richened up fuel mix.
added some 20 degree cooler crap to the coolant
WTF is going on? is the cam "too hot" for daily driver?
Engine 318 (unknown origin (maybe 76 dodge ramcharger)), Comp Cams .480 lift, duration @ .050 231, lobe lift .3200, lobe separation 110.0 comp cams pn#20-232-4. Holley 600, Edelbrock Performer 318/360, looks like stock exhaust manifold, Stock Distributor.
I have good water flow in radiator, a small 14" fan reversed to push because of water pump clearance (no shroud).
It just seems to generate a helluva lot of heat. Is that timing or what?
Help!!!
PART #CC64DT
DIMENSIONS:
fixes attempted:
Replaced radiator.
removed thermostat.
Help!!!
