340sFastback
Buy a kit but have a reputable local shop balance it. The term "balance" means different things to different people. Some companies take the manufacturers weight of the pistons, pins, rigs, rods and then "balance" the crank accordingly. End result is all the rods and pistons are different weight so it is not correctly "balanced". Don't fall for it, have a good local shop do the balance correctly.
And yes, with light rods and pistons internal balance should be not problem. The K1 cranks are nice, Scat I-beams are good, KB745 step dish pistons. You should pick up the book How to Build Big Inch Mopar Small Blocks. Lots of good info in there:
http://www.amazon.com/dp/193249457X/?tag=joeychgo-20
