Torque Converter Bolt Circle Wrong
MrJLR
Built, not bought
Menifee, California
Bummer....doesn't look like Friday will be drop-in day.....
The B.C. on the new converter is 4.85" and my flex plate is 5.5....or something like that. ...
Anyway, do I get a different flex plate or return the converter to Summit? They're great about returns.....
It's a 318 so neutral ballance.
Anyone wanna recommend a CORRECT part number for me?!!!
I believe this one (Hughes) is a 2200 - 2400 stall.....
Sucks, but I've waited this long, I'm gonna do it right.
Jeff
I found this info on Jegs website. The bolt pattern circle on your flex plate is supposed to be 10". Measure your flex plate from the center of one bolt hole to the center of another bolt hole (as long as its directly across from the other). That is your bolt pattern circle. Double check and let us know.
Hughes Performance 24-20
Hardware Included
No
Transmission Mfr.
Chrysler
Transmission Mfr. Code
A518 (46RH)
A727 (36RH)
Converter Hub Diameter (in)
1.876
Converter Input Spline
24
Converter Lockup
N
Converter Mount Type
4 PAD
Converter Pilot Diameter (in)
1.812
Converter Total Height (in)
5.500
Flexplate Bolt Circle (in)
10.00
46RE
47RE
Flexplate Balance Weight (lbs.)
N
Flexplate Ring Gear Teeth
130
Converter Mounted Ring Gear
Y
Anti-Ballooning Plate
No
Balanced
Yes
Furnace-Brazed
Yes
Input Spline Quantity
24
Lockup
No
Quantity
Sold individually
Manufacturer's Part Number:
24-20
I found this info on Jegs website. The bolt pattern circle on your flex plate is supposed to be 10". Measure your flex plate from the center of one bolt hole to the center of the flex plate and then double it. That is your bolt pattern circle. Double check and let us know.
Hardware Included
No
Transmission Mfr.
Chrysler
A518 (46RH)
A727 (36RH)
1.876
24
Converter Lockup
N
4 PAD
1.812
5.500
10.00
46RE
47RE
N
130
Y
No
Balanced
Yes
Furnace-Brazed
Yes
24
Lockup
No
Quantity
Sold individually
24-20
Ok....just a sec....BRB
Flex plates are made in different configurations, you need to measure and get the proper one.
Some cranks have symmetrical bolt pattern, some non-symmetrical...
Then some torque converters have 10" bolt spread, some 11"...
Figure out if your crank is symmetrical or non-symmetrical bolt pattern, then measure the converter bolt pattern for 10" or 11", then pick out the proper flex plate here:
Mancini Racing
Measured twice. ..11.000".
I was a machinist for 25 years...I'm lucky to have 12" calipers
Mancini Racing
Mine must be the 11" symmetrical.....ugh!
If they were open right now I'd be on the phone VISA in hand!
Thanks guys! I really appreciate it!
Jeff
Remember that Mancini Racing is on Eastern time zone, and you are pacific.... They are a few hours ahead of you, if you call them on the phone...
Yup...just triple checked. ....
They are both symmetrical....
My flex plate is 11" & my new torque converter is 10"
Calling Mancini in the morning.
It's not like I don't have tons of other stuff I can do and the engine will go in NEXT week!
Jeff
Probably more than the part cost.... :eek:
But if it's worth it to you to get it right away, go for it... It's only $$$$..... :D
The old time vs. money issue.... :rolleyes:
Naw...I ain't gonna. ....
I'm resigned that it isn't going to happen this weekend.
Oh well....There's always other stuff to work on!
Just glad I have an answer and it's pretty inexpensive.
Jeff
