Darwin
Evolutionary Member
I'm working on a 66 Cuda. Torsion bar mounts in sub frame are rusted really bad, almost non-existant. I'm contemplating removing the torsion bars completely, welding up the sub frame and replacing the front shocks with coil overs. Can this be done without major modification to upper shock mount? Is there enough clearance between the shock and frame rail? Will I need to go to a tubular upper control arm?
Does it even make sense to go to a coil over set up or am I better off repairing the stock torsion mount.
