I know, and stainless doesnt mean "will not rust forever" or "you can do whatever you want to it and it wont rust." However, my experience with stainless trim on older cars is that they normally dont rust. Which is why I asked. If I see a piece of steel that has rust on it, I typically will assume it is not stainless. Seeing as it didnt really look chromes, I was curious to know if it was in fact stainless. I also thought I saw heat marks from welding, which could have been the manufacturer marrying a carbon steel flange to a stainless strip. Given the flange had what appeared to be some sort of coating or plating (or maybe it was very mild corrosion), I am still thinking that might be a possibility.
