360moparjunkie
Looking to find oil pump bypass relief spring part # P3690944.
This spring should change bypass pressure from 50 to 70 psi.
I've called several places without any luck. Being told they're on back order.
Does anyone please have access info? This spring is holding up my project.
Local shop mentioned adding flat washers to end of spring to increase bypass pressure.
Has anyone used this method?
