Tunnel Ram on Street?
Small Block Mopar Engine
  1. Cope
    Cope Fusing with fire
    4,040
    4727
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    11:49 AM
    Paging @j par please come to the white curtisie phone.
    • Like Like x 2
    • j par
      j par Well-hung Member
      22,324
      11095
      Jul 2, 2014
      Portland Oregon
      Local Time:
      9:49 AM
      Yes I"m here. And if you want me faster pm me and it will send an alert. I am out of town so I won't check my phone as often.
    • Cope
      4,040
      4727
      Oct 20, 2009
      San Jose, Ca.
      Local Time:
      11:49 AM
      Just thought you may want to chime in on this one?
      • Like Like x 1
      • rumblefish360
        rumblefish360 So close, yet so far away FABO Gold Member
        37,800
        9485
        Jun 21, 2005
        New York, on a Island
        Local Time:
        12:49 PM
        IMO, if your going to use a tunnel ram in the street, then ether the current Weiand or the below Edelbrock with the smaller/thinner plenum.
        The M1 is a race intake.
        The Weiand and the below Edelbrock (with the pictures top) would be best for the street.
        Everything is in its cam, carb tune & useage.
      • j par
        22,324
        11095
        Jul 2, 2014
        Portland Oregon
        Local Time:
        9:49 AM
        Lazy ass... It's 4 bolts!
        • Like Like x 1
        • Thanks! Thanks! x 1
        • j par
          22,324
          11095
          Jul 2, 2014
          Portland Oregon
          Local Time:
          9:49 AM
          Good enough? LOL
          • Like Like x 1
          • yellow rose
            yellow rose Doctor of Thinkology.
            21,284
            17335
            Jun 19, 2015
            Living on the razors edge
            Local Time:
            9:49 AM
            Cope is having bromance withdraws with you in Colorado and pretty much ignoring everyone on FABO.
            Bring me back a T shirt or something.
          • nm9stheham
            nm9stheham Well-Known Member
            12,007
            3856
            Dec 20, 2013
            Waynesboro, VA
            Local Time:
            12:49 PM
            This intake juxtaposed with the washing machine says something.... I just don't know what... LOL
          • gzig5
            gzig5 Well-Known Member
            1,150
            1090
            May 3, 2018
            Mequon, WI
            Local Time:
            11:49 AM
            Would there be an advantage to isolating the front and rear halves of the TR? Essentially create a V4 fed by each carb? The tops are replacable, so it seems you could pretty much fab whatever you wanted for plenum volume on top. Go a step further and with two FITech or Snipers on there with the plenum isolated to each bore, it would be like having individual throttle bodies on for each cylinder which should give good response and help with the idle and part throttle tune?
          • yellow rose
            21,284
            17335
            Jun 19, 2015
            Local Time:
            9:49 AM
            Offenhauser made tops for TR bases that did that. The biggest issue was idle. It was a bitch to get them be even remotely happy at idle.
            They also had some weird linkage that had the rear carb with the primaries over the drivers side bank. That was a PITA to sync the carbs.
            So I remounted the carbs both facing the correct direction, made my own linkage and made the carbs open 1:1 and it still wasn't happy at idle. So I put a 1 inch hose between the plenums and it settled down.
            Steep learning curve with stuff like that.
          • 1Fast340
            1Fast340 Well-Known Member
            1,172
            372
            Dec 30, 2011
            Sweden
            Local Time:
            6:49 PM
            Tunnelrams are not only great on the right engine they are also great for improving the apperance of anyones home! I got one of those standing in an armchair in a room that is almost never used.
            • Agree Agree x 2
            • 1Fast340
              1,172
              372
              Dec 30, 2011
              Sweden
              Local Time:
              6:49 PM
              The carburetors mostly used on these engines realy dont like pulses and much prefer flow that is as steady as it can be,this is partialy why the plenums are connected,and i suspect the simpler TBI style fuelinjection systems wants less pulsing aswell for sensors to be happy.. If you want to build an IR manifold with carbs you want to use Webers or other similar carbs(I know Edelbrock carbs are marked Weber but no those are not going to be happy as IR carbs.) Racers sort of tried using dominators on tunnelrams as kind of IR manifolds and there is reasons why they are not doing it anymore.
            • gzig5
              1,150
              1090
              May 3, 2018
              Mequon, WI
              Local Time:
              11:49 AM
              Reason I ask is I've got a 2000 BMW M5. It is a 400hp 5.0liter motor that has individual throttle bodies for each cylinder with a 6-8" horn feeding each one. All hidden in the big box plenum. The throttle response of that motor is fantastic and I've been led to believe that part of that is due the individual throttle bodies.
            • Bighead440
              Bighead440 Well-Known Member
              290
              208
              Jun 18, 2017
              Milledgeville, Georgia
              Local Time:
              12:49 PM
              As was posted earlier, stay moderate with your camshaft if street driving the tunnel ram and spend the extra money for a calibrated pair of carbs. Forget 390/450cfm carbs unless you have a flathead Ferd. A friend took a 750dp/single plane (Victor) intake off his hot 340 4spd Barracuda and replaced it (at great expense) with a Weiand tunnel ram and 2 x 450s. Guess what? He slowed .5 in the 1/8, regardless of tuning. I begged him to go bigger with the carbs and he finally did. With two (cheap shelf units from Summit) brand new ProForm 750dp's, he got back his .5 plus .3, for .8 second total improvement over the single plane/carb, even with the sketchy ProForms.
              • Agree Agree x 1
              • rumblefish360
                37,800
                9485
                Jun 21, 2005
                Local Time:
                12:49 PM
                Huh?
                No, as mentioned, the carbs like to see a constant signal on this kind of set up. Carbs generally don’t like to start and stop. While fuel injection helps, the style best to use would be sequential port injection. Not a divided twin throttle body up high.
                This is a little bit of a different animal. It has every update we wish we could provide and then some. It has every advantage plus. But in a way, yes, you are correct. However, doing this on our older engines would require some serious fabrication skills. It is not undoable but just simply difficult. And probably cost prohibitive.
                That BMW probably has each runner tuned to what that cylinder likes best and the fuel injected into it is timed for best power and results. This is not as easy to do on a fast intake. Again, mad fab skills come in handy here
                Now is t it funny how a tunnel ram will work wonderful with 2-750’s where the single 4bbl. is limited by one carb? Even if it was the same size (750) or larger, the total cfm of the twin carbs is more than what you could reasonably put up to with one carb.
                • Agree Agree x 1
                • jas0162
                  jas0162 Well-Known Member
                  507
                  314
                  Apr 23, 2014
                  kansas
                  Local Time:
                  11:49 AM
                  Mine is an old Weiand and it has a single four barrel top. When I swapped out the torquer single plane on a 383, I used the same old 850 do with no mods. The car went from 12 flat to 11.8 with no other changes except for cutting a hole in the hood.
                  • Like Like x 1
                  • Bighead440
                    290
                    208
                    Jun 18, 2017
                    Local Time:
                    12:49 PM
                    That's those long runners helping the short stroke 383 with stock type iron heads out, that's what they were designed to do!!!
                  • jas0162
                    507
                    314
                    Apr 23, 2014
                    kansas
                    Local Time:
                    11:49 AM
                    Yea it ran great. It idled better and had better throttle response. Revved like a dirt bike. Piston failure at high rpm killed that one
                    • Like Like x 1
