Icantdrive75
Live75
In the process of converting my '75 Duster from a column shift to a floor shift using a B&M Megashifter, I installed a Column Shift Delete Kit (MP14054) and a new turn signal switch (MD2094) from Classic Industries. My old switch was shot; so it only made sense to replace it while taking care of the floor shift conversion. After I installed the new switch, it would not correctly cancel after completing a turn. I tried adjusting the switch itself and moving/rotating the ring on the steering wheel. After several unsuccessful attempts, I guessed that the ring on the steering wheel was just missing the cancelling cam on the switch...so I cut off a section of a plastic tip from a tube silicone sealant and slipped it over the ring on the wheel.... no more cruising down the road like a jackass with a turn signal on for 5 miles!
