dart_68
Venting a little...
Redoing the steering column on my 73 Duster as the original turn signal switch in the column is broken and won't stay locked in left turn. Turns out the plastic is broken. I order a new one...surprised to see them readily available. Don't remember at this time who I ordered it from. Wasn't Rock Auto but a similar supplier.
I get everything back together and installed and I happen to look at the ammeter and the needle is moving back and forth a little to the left. Gotta be either the flasher is on or the turn signal. Come to find out it's the turn signal. But the ***** about it is that it flashes in the up (right turn) and middle positions and is off in the down position (left turn). WTF!
I'm guessing the new wiring is not wired correctly? Looks like I'm going to have to order another one from another place. Recommendations on who sells the right one?
