manderson1356
Member
Early 1976 Dodge Dart base sedan,
I'll start this off with this, I'm looking for advice on a "do the wrong thing, the right way" sort of fix, I'm working with the combo of having a tight budget and very little electrical experience. With that said my turn signals have quit on me, bulbs are good, new flasher relay, and hazards still function. Essentially what I need to know is this, how can I, if possible, bypass the column mounted switch and use my own? I've explored all around the wiring harness and can't seem to see anything unusual, but I also know almost nothing about wiring short of simple two wire power/ground stuff. If I had the means (time/money), I would have it done right, buts that's not the case, so please don't reply telling me to do so, I'm aware of what I "should do". Any help in this matter will be greatly appreciated, also a breakdown of what the wires are that go into the steering column would be grand as well.
