Unfamiliar with Mopar’s need help
hunukenny
New Member
colorado
Hello, I just got my car recently and I was wondering how I would go about adding a sway bar to the front of my car? The Scamp doesn’t have the mounts for it so I assume it didn’t have one from factory.
Thanks for the help
Most of the aftermarket sway bars will include the outer brackets that either need to be bolted or welded to the lower control arms. The Hellwig 55905 included mounts that can be bolted or welded on, the Hotchkis #22386F used to come with weld on brackets but apparently it's not available now by itself, just as part of the TVS kit.
You can also contact @BergmanAutoCraft, he sells weld on tabs and has several sway bar options
Thanks for the help
There is an aftermarket sway bar from Hellwig that I put on my 73 Dart. Took about a day because I ran into some issues but it definitely help the car understeer and diving into the turn. Much flatter now. I can't remember if my K-member had factory ears for mounting the ends or not. There was some drilling to do but not too difficult.
Search by Vehicle - Hellwig Products
The Hellwig kit does not require welding. The tubular bar is also cool because it is much lighter than a solid bar. Hellwig's brackets that attach to the crossmember are much better designed than some, such as Addco for example. Recommended.
Let me just say this: Whatever you do to end up with an anti-sway bar, I guarantee you it is worth the trouble
I put an Addco bar on the front of my 64 Valiant. The Addco bars themselves are fine, but their hardware kits leave a lot to be desired. That's why they have a cheaper price. I got a universal mounting kit from Energy Suspension and that made it really nice.
so I wonder what my car has been through. Lol
If only cars could talk! Wait a minute; come to think about it, it's probably a good thing they can't.
I installed a Hotchkis swaybar on mine. I had to weld the brackets on. It made a big, positive difference.
