Upgrading from stock disc brakes (70 Duster 340, B51 option)
Drewster
Member
Centreville, VA
So, I've found myself in a pickle and can use some help because I have been unsuccessful in finding an appropriate answer - which is why I'm turning to the pros!!
My 70 Duster 340 is a true B51 (Power Asst. Disc Brakes) car with the SBP. I'm looking to upgrade rotors to something beefier and don't want to replace the spindles or any of the components that don't need to be swapped - but can't find anything for a 70 with stock disc brakes (that doesn't cost a fortune!)
Can I use a disc brake upgrade from a 73-76 Duster or any E-Body without hassle?
I'm not tied to the SBP. In fact, I'd like to upgrade so I can throw the wheels from my 71 Dart on. However, I don't want to hack into the car since it is numbers matching and I'd like to be able to keep the components in case I ever have to part ways with the car.
I haven't checked the availability other than looking at wilwood and SSBC. I have the wilwood dynalite 4 piston on an Alter-k-tion sitting on my Dart and love the look and feel. I suppose I'm really looking for the easiest way to put that brake assembly on the Duster.
